Well it looks like I can't get into my car.
The stupist answer just came to mind! can't get either door to open?
Remove the inner fender well on the right front side, cut open the rubber flex hose which runs between the door and the body. (or try to disconnect it from either end. It has one screw to hold it to the door) Then pierce the wires that feed to the switch for the power window motor! Then run 12v from a jumpercable through and make the window roll down! the feed wires (which come from the drivers side switch) will be a thick tan wire and a thick Light blue wire! -Ken
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
  • 5speedz34
    9
  • Prospeeder
    6
  • nebojsa_o
    4
  • gp90se
    3
I got in!
My friend dremeled part of the handle out and then we got to the rods.
Itwas very easy.
MORE TOMMOROW!
excellent! sort of :lol: don't forget to check the link above for handles.
and I SOOO liked the idea or piercing into the PW wires!!!
Like I said I'll put something up tommorow sometime I need sleep though!
