Top Engine Cleaner
I need the part number for the GM stuff. The dealers around here are claiming they have nothing of the sort.
Please and thank-you
I been thinkin about cleens. Its made by AC Delco
I assume same shit different pile?
avenue west sells delco shit.
I think it would work better then generic brand,
as some people have used delco cleaning products and found them better than generic crap
Oh man. GM Canada calls it something different.
I can't think of the name to save my life. Ah fuck, I'll think of it two hours from now.
I'll be waiting...
No pressure :)
GM Top Engine Cleaner # 1050002
or
Cleens # 992872
THANKS a ton
Anyways GM Canada has replaced 1050002 with 992872
So there is no "GM Top Engine Cleaner" as it is now Cleens
The guy gave me all these warnings as the shit is soooo deadly. But he says the stuff works magic.
Thanks again Manny
How do you use this stuff? The top of my engine has about 110,000 more miles on it than the rest of my enigne :)
slowly suck it into the engine using one of the vacume lines, and watch the car smoke like at bitch for a while. The stuff works wonders.
so is it basically the same thing as seafoam? that, and how do I make it so that the brake booster line doesn't pull in too much at once?
can you use a small vacuum line, like the one off the HVAC check valve and just stick it in the bottle and suck it up? the PM3 doesnt have a brake booster
Use the vacuum port for the tranny (right after the throttle body) with a piece of hose.
Rev it up a bit while you do it if you think you are gonna have problems stalling it. You might possibly need an extra set of hands not I never did.
I just did it with some seafoam... no white smoke and no noticable improvment. I didn't use very much, so should I just try again with a little more?
Use the whole bottle, suck it in slowly then when you get to the bottem let it stall out. Leave sit for 10-20min so that the stuff can eat away at the crap. THEN go out and drive....
I used a bottle of simple green on my accord, took about 2 hours, but that thing looked good after I got it clean. Thats what I would reccomend.
I PMed Jeremy to make a thread in the FAQs for top engine cleaner. I dunno who many times this has been covered, it's ridiculous.
Ya don't use that INSIDE the engine lol.
