On my FWI, how do I install the IAT sensor?....grommets?
Ya, like the title says. How do I make it so the Intake Air Temperature sensor stays in the pipe and doesn't come loose?
grommets?
On inside and out?
On the stock airbox where the IAT actually sits at, there is a little metal clip that actually holds that in. I drilled the size of the stock hole into the pipe, put the IAT sensor into the pipe, and put the metal retaining clip into the pipe. Works just like stock.
EDIT: I tried looking for some pics on my computer, but I guess they are only on my parents computer back home.
Remember, i've got the 3100, is its IAT different than the 3.4?
I looked for a metal clip, but it's not there. I tried to pull it out, but to no avail.
How do I get it out?
i have tones of gromets because i make the cai. do you want me to send you one or i am having CUTTY test a cai for the 3.1 and can make you a hole kit soon
My IAT sensor looks like the one on the right.
Its the pullout kind.....can i Re-use it in the metal pipe i'm using...?
