For those who glassed before
well i went and got 4 yards of fleece its like sweatshirt fleece about the same thing as t-shirt fleece. got it for 2 bucks a yard.
Edit: Does it usally take alot of resin to do the fleece cuz i just did 2 sides (front and one side) and i've used alot of resin doin it and i cant really get it soaked that good...
well i finally got it rather nice lookin on 2 sides but yea it needs work. Thanks for your help guys
Hey i got another ? do i need to put fiberglass over top of the fleece? or just like 2 lays of resin? and it didn't dry to smooth either so it needs sanded alot
If you want to use the fiberglass matting itself, use it on the non-visible side of the fleece(the underside). The matting is a bitch to sand.
is it possible to fiberglass over plastic? some sites i read say you can ,some say you cant at all, and some say its a huge pain.
they say it won't stick, i have yet to try it, but my cousin did it on his coloum for a gauge pod and it worked. What he did was cut a few holes in the plastic so the fiberglass had something to grab onto.
for some reason i have a feeling that im goin to have to bondo the entire thing really good cuz the box is extremly ruff even after i sanded it
If it is a sealed box, it needs the added stiffness. Ported boxes it helps, but the bass obviously is not under pressure as much
It won't stick.
fiberglass jelly sticks to plastic pretty well. i did my old center console with it.
He didn't know what he was doing at first.
That looks pretty kool all glossy. That stuff makes a good glaze finish on plastic. but if you fiberglass a flat piece on plastic it will peel right off. I like the skull, is that resined to the console?
the skull is fiberglass, yes. then the rest of the console is coated in resin jelly as well.
2056262_21_full.jpg this plastic factory speaker pod with a boston 4 inch mid sounds really good. but it separated on the face plate and I had to glue it back down with epoxy. then it was fine.
