lutman123 Posted November 14, 2005 Report Share Posted November 14, 2005 I am swapping a 94 ponitac grand prix with a 95 lumina both 3.4 DOHC. There have been a few differences between the two engine, all minor. But now I have the lumina engine in the car and on the GP engine there is a crank positioning sensor under the harmoninc balancer, and there is not one on the lumina, does it have one somewhere else? I was wondering if maye when they took the engine out of the lumina they may have broke the wires off and that is why I can not see it.I have not removed the harmonic balancer on the Lumina engine yet because it is in the car now (doesn't it figure) and it is going to be a pain in the butt to get it off, if anyone can help me that would be great, I am kinda at a stand still right now. thanks Quote Link to comment Share on other sites More sharing options...
EurosportZ34 Posted November 14, 2005 Report Share Posted November 14, 2005 as far as i know they did not change the LQ1 at all from 1994 to 1995...the only changes were from 1991-93, 1994-95, and 1996-97 model years Quote Link to comment Share on other sites More sharing options...
lutman123 Posted November 14, 2005 Author Report Share Posted November 14, 2005 So if I remove the harmonic balancer on the lumina I will have the same sensor there, all I will have to do is just change it out? Quote Link to comment Share on other sites More sharing options...
lakefxgp96 Posted November 14, 2005 Report Share Posted November 14, 2005 Now it sounds like both motors should be SFI, but maybe one isnt.... If its SFI, you will get a bigger harmonic balancer that has the interupter teeth on it for the crank position sensor. the other senosor i beleive is only used to find TDC in this case???? it still has the other crank position sensor that the <95 uses on the MPFI you will have only the crank position sensor in the block. and the balancer is just a a wheel with 3 spokes that the pulley attaches to. Im certain both are SFI, and im not sure that the 'crank position sensor' on the lumina motor is necesary in that car...but if its there it should be directly behind the alternator. EDIT: I reread your post 4 times and i think i changed my answer 4 times :oops: i think ive got it now though Quote Link to comment Share on other sites More sharing options...
lutman123 Posted November 21, 2005 Author Report Share Posted November 21, 2005 just to let everyone know, that senson is located in the same spot on both engines, after I took off the harmonic balancer on the Lumina engine there it was. They just completely ripped off all of the wires when they took the engine out of the other car. Quote Link to comment Share on other sites More sharing options...
