hot air one day gone the next...
well my car isnt pumping out any hot air . it worked the day befor the fan kicks on when i put it on max but cool air blows... What gives?
is the carpet on the pass side floor wet? You might want to check that, or your thermostat might be stuck open. I'd check them both
What does this mean?
I've knoticed the floor in my Lesabre gets wet sometimes and the heat doesn't work. I always thought it was some other leak but is this the true corrilation?
the floor isnt wet but the car is running at 220 at idel then goes to 180 on the highway?
Most likely your core is plugged with goooooo.
Need to back flush it and get the crap out of the core. Find out which way the coolant travels through your heater core. Remove both hoses on the engine side of the firewall. Put a garden hose up against the return side with just enough pressure to get the water flowing. Too much and you will blow your core in half. With the water backflowing until it runs clean, hook everything back up and you will have heat again. :wink:
theres 2 coolant hoses that go inside the car right behind the engine, those go to the heater core
the core itself is under your dash inside the car, and requires taking most the dash apart to replace
that sucks but ... I took the whole dash off befor and lock tite all the srews b/c it would shake its self apart.
