getwill Posted November 12, 2005 Report Posted November 12, 2005 need to know what car i can get one from and does anyone have one
z34Phoenix Posted November 12, 2005 Report Posted November 12, 2005 what year is it going into? if it is a 97 DOHC then you will need a 4t65e if it is a 96 or a 95 and below you will need a 4t60 the 60 came in many different cars including 3100's but the problem is they changed the gearing for the dohc. so the cars you will need to look at are: they all need to have a 3.4 DOHC but here are the types of cars i know that have that motor. this motor is rare so good luck. Grand prix's Cutlass's monte carlo's lumina z34's they stopped using the 3.4 dohc in 96 for most of these and went to 97 for the lumina, monte ps also, if you are running a modded dohc, which your profile lists, i would suggest either get a rebuild with HD parts and deffinatly a trany cooler, or get a new PCM set for 97 and run the newer 4t65e. the 60e's have tons of problems and can be trashed even by a factory engine. the later 65's were stronger and last better.
getwill Posted November 12, 2005 Author Report Posted November 12, 2005 A 96 motor will run with a 97 pcm?
