My 3.1 runs great, no problems
It sure does! even with 250,000 + miles on it! Compession is the same in all cylinders. roasts the tires at will.
I just put over 500 miles on my buick, got 36, yes 36 mpg doin 75mph going down, a bit less doing 75-90 on the way home.
3.1s are great motors for what they are, just not powerful
3100s are a different story
i dunno what you're talking about...34mpg beeoch!
The intake gasket thing is pretty minor if you ask me
You should still be able to catch it before damage occurs....Water in oil/Overheating/Coolant Consumtion...just pull it over! Not rocket science
Yeah...got 34 on my way home from Michigan on Memorial Day weekend...went 65 the whole way...I usually get about 29-31 going 70-75
How are you guys getting such good mileage numbers? My window sticker rates my car at 19/30 MPG, but you guys are besting that by 4 MPG or more on the highway! Usually older high mileage cars are below the EPA rating.
it's all about making the car run as well as it can. my buick slips in 2ed gear some and I need dogbones again :? but even with the original wires, a stock paper air filter and slight lifter tick, my 3.1 purrs. Only things I have done to the car (car has 78k miles) is cleaned out the top end, changed the plugs, disconnected the EGR and changed the oil.
My car has 38k on it...although my sister did the same with hers that has 92k on it...but it had a brand new intake gasket in it, brand new fuel filter...
Really, the key is just driving the same speed all the time...sometimes i use the cruise, sometimes i don't. Even on work term during my commute, I still get about 25. keep the speed between 65 and 70 and the old 3100 just sips the gas. I honestly accellerate pretty fast from every stop. The worst mileage i have gotten since I bought the car was 20mpg.
Don't get me started about the 35mpg hwy (its rated at 34) with the Quad 4 DOHC lol
Done that.
changed the plugs
Done that.
changed the oil.
Do that of course.
What does disconnecting that do?
With a digital EGR, it has to be programmed not to come on, on a vacuum egr, you can block off the vacuum port to the TB so it never opens up. Mine is faulty and work make the car idle a little off, with the vacuum line plugged, idles mint.
