The vacuum line on top of the transmission.... where does it go?
Is the connector pictured in this image on the front of the transmisson the TCC solenoid?
1.) That's not a vacuum line, that's the Detent Cable, it should be connected to your throttle body.
2.) Yes, that's the TCC solenoid plug, unplug it and see if your problems cease.
Guest TurboSedan
where exactly is the other side of the line connected to?
my Getrag has a vent tube....it just goes up to a pipe that is mounted on the driver's side fender. the pipe is just curved so no water/debris can fall into it. if that IS a vent tube in your pic, than no, it doesn't really need to be connected to anything, just make sure nothing can fall into it.
I see the channel on the fender, thanks for all of your help!
