sdoDrew Posted March 3, 2003 Report Posted March 3, 2003 Mine is fucked in the head, I stall because my car can't maintain a proper idle. I heard that removign the fuse for the comptuer then putting it back in resets it. then you start your car, let it idle in drive for 5 mins. shut it off, start agian and let it idle in drive again for anotehr 5 reprograms it My question is, does this work, and where to i find the fuse for the idle computer? I am driving a 1991 cutlass supreme sl 3.1 V6 thanks guys Quote
Robby1870 Posted March 3, 2003 Report Posted March 3, 2003 Did you recently have you battery disconnected?? Cuz if you do that, the car wont idle properly and it had to relearn idle. Let me know on that...... Robby Quote
Bake82 Posted March 4, 2003 Report Posted March 4, 2003 I kinda have the same problem with a low idle and have had the battery unconnected in the past 2 months, but I kinda had a bad idle before. I guess any help would be good with this! suggestions for the both of us! thanks in advance!! Quote
Guest Anonymous Posted March 4, 2003 Report Posted March 4, 2003 Pull the ECM fuse and put it back in. Start car and put it in overdrive. Hold brake and let it idle between 5 and 7 minutes. Shut car off, start car and do it again. Quote
sdoDrew Posted March 4, 2003 Author Report Posted March 4, 2003 yeah i have been doign a lot of electrical work and the battery has been disconnected, which fuse is the one for the idle computer? I check my Haynes manuel and my car manuel and i still couldnt find it. Quote
Guest Anonymous Posted March 4, 2003 Report Posted March 4, 2003 There is no idle computer. You need to pull the ECM fuse. Go back and read my other post. Quote
