Distribution block?
Anyone know where i can find a distribution block for a input of 2 gauge and output of 2 4 gauge wires? i looked everywhere and i cant find one
There arent going to be many with only a 2 guage input. But alot of the 0/1 guage distro blocks will accept 2 guage inputs. If all else fails just strip the wire back a little further and double it over.
But sounddomain has a few that might work for you. And their are verying models depending on if you want a plain distro block or one with a fuse built in.
http://www.cardomain.com/item/STISDB3PT
Or something like this where you can just put a ring terminal on the input wire.
http://www.cardomain.com/item/STRFBR24S
parts express is going to be the cheapest, I don't care about price matching, no one can offer the selection they have.
If you can't find any that are specifically made for car audio, then head to an electrical supply store (or even check out Grainger - their website is www.grainger.com . )
If you use an "industrial" distro block, you'll probably have to use one of those ugly gray enclosures, or make your own out of plexi.
Now the more that I think about the subject, Home Depot carries a limited selection of electrical supplies, and I'm almost positive they have "industrial" distro blocks. Might want to head over there first...
Well, I was going to say, if you are doing the ground, just use a bolt/ nut/ lockwasher.
those gold battery "side mount" terminals got a gold lockwasher. and you can drill/ tap the trunk floor right where it welds to the frame and catch a good thread from inside your trunk! something I have never seen anyone try!
Now that would be the ultimate ground!
