Hey Guys,
I am toying around with throwing a 5 speed into the cutlass and I have done alot with the search function but still have a few questions.
First off, how hard is this swap to do? Is it a drop in application or does it involve alot of custom work? I really would like to drop the subframe, pull the auto, put in the 5 speed, and be done with it. Now, I know it wont be that simple, but I don't want to spend alot of time getting it to work either. I have a busy winter for this car and it may or may not be too big of a project to tackle this year.
Second, I would probably look for a wrecked car to use as a donor. I have good relationships with a few of the local yards here. I am planning on walking around and looking for a donor car this afternoon. What car should I look for?
Lastly, I have seen a few posts on factory 5 speed Cutlass'. Did they make the 3.1 5speed as a combo or was it just the 3.4 that came with the manual?
Any helpful info would be appreciated.
Thanx guys...
-Sean
Sean,
Here is a link to everything you will need.
http://www.w-body.com/forum/viewtopic.php?t=29613&highlight=swap
Since your's is a 94, you will need to do some extra work for the clutch pedal. I can not remember exactly what is required to be done, however there are 2 guys on the board who have done this swap into a 94. Soccar playgtp was one and briag89gp was another(their names are close enough to that anyways) I think you need to change out the firewall plate aswell as add the support for the clutch pedal. It's alot more work that the 88-93 guys. but it can be done.
Also they did make cutlasses with a 2.8 5 speed, and with the 3.4. 5 speed. However you are not limited to just the cutlasses. You will probably have better luck finding a Grand prix 5 speed. 88-90 was 2.8/3.1 and 91-93 would of been 3.4.
Either way good luck!
If my info on the years is wrong sorry!!
So maybe my best bet is to search for a 5 sp grand prix? I am assuming then I can use all the pieces you said I needed to change from the donor car? I will look for a 5sp cutlass too but I agree with you, I am better off finding a gp. Sounds like it could be doable.
I am also hard into the Taurus SHOs. I have a complete parts car in my barn, If I had the time and money I would throw a 3.0 yamaha v6 mated to a manual and have one heck of a couple. Oh well, probably wouldnt fit anyways.....
thanx for the info
Sean
I'm not saying don't look for a cutlass. Look for both, but I'm saying it will be easier to find a GP. And all of the parts should bolt up to your car. I got my 5 speed parts from a GP and so have many others who have done the swap that have a Cutlass.
Your biggest issue, like I said will be mounting the clutch pedal and firewall plate. Somebody with more knowledge about the 94+ will have to step in and explain exactly what needs to be done for that.
That's all I know..lol...Good luck and I hope this helped.
trust me, it's helping. I am glad to know it is mostly a bolt-in process. I was planning on dropping the subframe anyways this winter to powder coat most of the engine stuff. Now I just have to find a donor car.
thanx
Sean
i think your car may require a swap pedal/steering column bracket. i'm not 100% sure what year it was, but i believe 94+ ws use a bracket that does not have a space for the clutch pedal.
if that's the case, you'll have to remove your whole dash to do the swap
94 is OBD1.5 isn't it? That means you will have to either convert it to the older OBD1 (so you can put in a 5-speed memcal) or get your PCM flashed ($$$)?
isn't there a way to wire the trans pigtail to fool the computer like the l67 guys do?
