Reverse Glow Ligths
Ok, so I bought some gauges off Ebay, and to my surprise, no instructions. The actual installation is not what will get me, it is the wiring, and even that I am sure I could figure out. But, if anyone knows how to do it, could you let me know?
Use a wire tap to tap into the dark brown wire at the headlight switch, and connect the red wire there. You can attach the black wire to any metal spot on the dash.
You want to connect the power to the parking light(s) wire, which is what the dark brown wire is, and not to the dash illumination dimmer wire (IIRC, it's orange.)
  • 1 month later...
I still haven't put it in. If I connect it to the parking light switch I will have to actually turn on my headlights, right? I can't remember the last time I actually manually turned my headlights on.
