badassoldspower Posted October 25, 2005 Report Posted October 25, 2005 I was checking my spec sheet on my spare tire cover and i found that i have the suspension code FE1 and I found that really odd because my car has a factory rear swaybar. Correct me if im wrong but FE1 cars did not come with rear swaybars. Quote
mfewtrail Posted October 25, 2005 Report Posted October 25, 2005 They come with rear sway bars. From what I remember FE1 Regals don't get the rear sway bar though. Quote
badassoldspower Posted October 25, 2005 Author Report Posted October 25, 2005 Okay I though my car may have been a factory freak Quote
1990lumina Posted October 25, 2005 Report Posted October 25, 2005 Your's isn't the only one....there are quite a few "factory freak" cars on here Quote
badassoldspower Posted October 25, 2005 Author Report Posted October 25, 2005 Yea!!!! My cars a feak! Quote
ToroToro Posted October 25, 2005 Report Posted October 25, 2005 My FE1 doesn't have a sway bar... Quote
badassoldspower Posted October 25, 2005 Author Report Posted October 25, 2005 that blows you should call oldsmo.......o wait gm killed that line oh well, you can by my stocker off me once i get my addco bar! Quote
GutlessSupreme Posted October 25, 2005 Report Posted October 25, 2005 They come with rear sway bars. From what I remember FE1 Regals don't get the rear sway bar though. Â My Cutlass doesn't have one.. Quote
mihela816 Posted October 25, 2005 Report Posted October 25, 2005 Some FE1's had it some didn't. It doesn't correspond to a make. My 2.5 Lumina had one, and my 3.1 Lumina didn't. It's the other way around now, heh. But regardless the FE1 rear bar is smaller than the FE3 bar, and smaller still than the 3.4 equipped rear bar. Quote
badassoldspower Posted October 25, 2005 Author Report Posted October 25, 2005 i know it basically as useful a "poopy flavored lollipop" quote "Dodgeball" Quote
Brian P Posted October 25, 2005 Report Posted October 25, 2005 check your label again. Unless '96+ was different, you should have FE7 which has the rear swaybar. Quote
badassoldspower Posted October 25, 2005 Author Report Posted October 25, 2005 Okay you are right my friend but it has FE1 and FE7 go figure on that. :? Quote
94CutlassSLCoupe Posted October 25, 2005 Report Posted October 25, 2005 Mine is just FE1 and didn't have a rear bar... Â Its got one now, and yes it makes a big difference Quote
19Cutlass94 Posted October 25, 2005 Report Posted October 25, 2005 My FE1 doesnt have a rear sway bar. I should probably get one though. Quote
94CutlassSLCoupe Posted October 25, 2005 Report Posted October 25, 2005 i pulled my own at the junkyard...they charged me $10...I suggest getting one out of a DOHC car though as it is supposedly larger (mine is from a '92 Z34) Â You will have to take the passenger side strut out of the car to get it in, just so you know. Quote
19Cutlass94 Posted October 25, 2005 Report Posted October 25, 2005 How much of a difference did it make? I have a rear STB, and that alone made such a huge difference   But what cars can I pull the rear sway bar out of? (ones with a DOHC as it is bigger and would probably help my handling better) Quote
94CutlassSLCoupe Posted October 25, 2005 Report Posted October 25, 2005 I don't have a rear STB...but it corners very flat in the back now, and as a result makes the front corner flatter...it also "pushes" less. Â Well the rear bar will work as long as its out of a 1st gen W-body...You will either have to buy inserts for your frame ($25) or pull them out of the junker. I would get one from a DOHC car but that maybe just me. Â My tires suck and i still beat people at autocross (FE1 Steering Rack=shit for sloloms)...only other mod is a front STB from a 'vert. Plus this car is pretty slow...so that can't help Quote
cutlass1991 Posted October 25, 2005 Report Posted October 25, 2005 Is this just for coupes? I have a 91 cutlass sedan and I'm looking to add a rear and maybe front sway bar if possible, I dont think my car has either. Quote
ToroToro Posted October 25, 2005 Report Posted October 25, 2005 Any first gen sway bar will work in your sedan. They have the same suspension as coupes. Quote
ToroToro Posted October 25, 2005 Report Posted October 25, 2005 And BTW, all W's have a front sway bar. Quote
cutlassdude96 Posted October 26, 2005 Report Posted October 26, 2005 I have FE1 and a rear saybar Quote
mfewtrail Posted October 26, 2005 Report Posted October 26, 2005 My 93 GP was originally FE1 and had a rear 10mm(?) sway bar on it. Every other FE1 equipped GP I've seen the undercarriage on has had a rear sway bar as well. I haven't really looked under many cutties, but I have seen at least one FE1 cutlass with a rear sway bar(changed out a starter on it at the shop earlier this year). Quote
19Cutlass94 Posted October 26, 2005 Report Posted October 26, 2005 I must have got ripped off then! Quote
