rshissler Posted October 15, 2005 Report Posted October 15, 2005 Whats a good way to kep my box from slidin around? Should i just screw it fast to the floor or would those rubber feet things stop it? or any other way to do it Quote
Garrett Powered Posted October 15, 2005 Report Posted October 15, 2005 you use construction foam, but you have to use aluminum foil and spray adhesive first. Quote
19Cutlass94 Posted October 15, 2005 Report Posted October 15, 2005 you could try some velcro (sp?) on the bottom of the box so it can grip the carpet in your trunk. Quote
Cam'ron Posted October 15, 2005 Report Posted October 15, 2005 i tried velcro in my buick but it didnt help very much at all the velcro doesnt grip as much to the carpet as you might think Quote
THe_DeTAiL3R Posted October 15, 2005 Report Posted October 15, 2005 I have the same problem. I think what I might try doing is taking out the speaker, and drilling some screws so that they go threw the wood and would "claw" into the carpet. Quote
badassoldspower Posted October 15, 2005 Report Posted October 15, 2005 Ummmm then when your carpet starts sliding around, what are you gonna do when the woofer goes with the carpet? I have mine secured with two L-brackets that are fastened to the RSTB Quote
Cam'ron Posted October 15, 2005 Report Posted October 15, 2005 thats what i ended up doing... my box was a custom built one that sat up on the "shelf" in the back of my buick and i just used 2 L brackets and bolted it down Quote
19Cutlass94 Posted October 15, 2005 Report Posted October 15, 2005 Shit, you or can just have a fucking beast of a box like mine (weights 86lbs with the subs and amp :oops: ) That fucker will be guaranteed not to move Quote
1990lumina Posted October 16, 2005 Report Posted October 16, 2005 Shit, you or can just have a fucking beast of a box like mine (weights 86lbs with the subs and amp :oops: ) That fucker will be guaranteed not to move No wonder you are saying your car is slow going up hills !! Quote
Garrett Powered Posted October 16, 2005 Report Posted October 16, 2005 I got a 50 lb speaker, and the amp and battery are each 50 lb+/- 10 lb. With everything in the trunk, it has got to be over 150 pounds! maybe 175. I don't know if my 350 Ft.lbs. of torque will even move it Quote
19Cutlass94 Posted October 16, 2005 Report Posted October 16, 2005 Shit, you or can just have a fucking beast of a box like mine (weights 86lbs with the subs and amp :oops: ) That fucker will be guaranteed not to move No wonder you are saying your car is slow going up hills !! Well its less than having another person in the car, so that shouldnt be an issue on this hills But yeah, its a beast Quote
96GranSport Posted October 19, 2005 Report Posted October 19, 2005 I actually screwed 4 hinged L brackets to the floor of my trunk and to my sub box. I made the holes on the floor a bit larger and put in Molly bolt style plugs. That allows me to unscrew the bottoms when I need to and move the box around without worrying about stripping out the holes. I also used some silicone to seal around each hole so no moisture would come up through there. Just a thought. Quote
jeremy Posted October 19, 2005 Report Posted October 19, 2005 not permanantly mounting it and allowing it to move around is good because it gives you easy access in case you need to throw the sub box at someone during a race. Quote
GP1138 Posted October 19, 2005 Report Posted October 19, 2005 not permanantly mounting it and allowing it to move around is good because it gives you easy access in case you need to throw the sub box at someone during a race. OMG T3h WINNAR PO5T!!!!111 :lol2: Quote
servoalt Posted October 19, 2005 Report Posted October 19, 2005 I got a 50 lb speaker, and the amp and battery are each 50 lb+/- 10 lb. With everything in the trunk, it has got to be over 150 pounds! maybe 175. I don't know if my 350 Ft.lbs. of torque will even move it Wow, that's impressive. What do you have, the MTX jackhammer? My TS-W2504SPL Premiers are only like 24lbs each so I'd love to know what you're running. My amp is maybe 10lbs and box maybe 60lbs (slot port 1.5 cu. ft. X 2). Where do you get a 50lb amp or battery by the way? You might want to downgrade to what everyone else on the planet is running. Just a little poking fun is all. Quote
Garrett Powered Posted October 19, 2005 Report Posted October 19, 2005 It is a JL Audio w-7 13.5" DVC sub with 3 ohms/coil The coils are ran together and pull 1.5 ohms out of the 1000 w monoblock. I picked up the amp the other day and the SOB was alot heavier than I remember. The battery is a Bi-Mart deepcycle/RV battery. Quote
AWeb80 Posted October 22, 2005 Report Posted October 22, 2005 I fastened my box to my Rear STB..... Quote
fender2082 Posted November 1, 2005 Report Posted November 1, 2005 Build/buy a box that fits your trunk? Quote
