Pabz Posted October 15, 2005 Report Posted October 15, 2005 Idler pulley decided it wants to fall off. Its been making wierd noises these last couple days, why this right after i got a wheel alignment and after putting in the intrax springs? Need new one, I am starting this tommorow, any help is greatly apreciated!! Quote
Guest TurboSedan Posted October 15, 2005 Report Posted October 15, 2005 they are really really easy to replace. just one 13mm bolt and i think the torque spec is like 40ft/lbs? replacing the tensioner and belt shouldn't take more than 5-10 minutes tops. Quote
GutlessSupreme Posted October 15, 2005 Report Posted October 15, 2005 Unless, of course, you strip the bolt. For the love of God, don't strip the bolt. Quote
Guest TurboSedan Posted October 15, 2005 Report Posted October 15, 2005 yeah then you'd be looking at a timing cover replacement. which really isn't too hard to do either. Quote
digitaloutsider Posted October 15, 2005 Report Posted October 15, 2005 Unless, of course, you strip the bolt. For the love of God, don't strip the bolt. I stripped the bolt once Quote
THe_DeTAiL3R Posted October 15, 2005 Report Posted October 15, 2005 Same thing happened to our 95 Lumina APV van 3.1, which has less room to work in the engine bay. However it wasn't a difficult job, should be easy on w-body. Quote
Pabz Posted October 16, 2005 Author Report Posted October 16, 2005 Well I went out bought a new tensioner $70, the pully that comes with it is made of plastic, it looks the same as the stock piece but when he brought the tensioner he also brought a replacement pully it was made of metal so i decided to buy that as well. $20. Also picked up a new TPS $55. Oh and new serp. belt $20. Put them all on, relearned the idle, and my car runs GREAT NOW. Idling around 990 RPM. Transmission is shifting alot smoother when punching the gas. And it seems the valve knocking is gone, but i am sure it will come back. Thanks for all your input folks. Quote
99RegalGS Posted October 16, 2005 Report Posted October 16, 2005 You're alot luckier than I was a few years ago. The water pump on my Regal was on the way out. I had just gotten the new water pump and was driving home from the parts store when my belt was thrown off the w/p pulley. The belt caught on something and got ripped in half. Then the belt started wrapping around my crank pulley, snapping my crank position sensor off. Killing the engine instantly. Yay. Quote
5speedz34 Posted October 16, 2005 Report Posted October 16, 2005 You're alot luckier than I was a few years ago. The water pump on my Regal was on the way out. I had just gotten the new water pump and was driving home from the parts store when my belt was thrown off the w/p pulley. The belt caught on something and got ripped in half. Then the belt started wrapping around my crank pulley, snapping my crank position sensor off. Killing the engine instantly. Yay. That sucks. Totally. Quote
GP1138 Posted October 16, 2005 Report Posted October 16, 2005 You're alot luckier than I was a few years ago. The water pump on my Regal was on the way out. I had just gotten the new water pump and was driving home from the parts store when my belt was thrown off the w/p pulley. The belt caught on something and got ripped in half. Then the belt started wrapping around my crank pulley, snapping my crank position sensor off. Killing the engine instantly. Yay. :shock: Quote
99RegalGS Posted October 17, 2005 Report Posted October 17, 2005 Yeah, it sucked. Ended up having to take it to a shop because they said the CKP needed an alignment tool. Which I found out a year and a half later that it can't be adjusted at all!! Quote
