f_399 Posted October 14, 2005 Report Posted October 14, 2005 I was here before because my radiator was leaking I got my radiator fixed and in the process we had to open the coolant bleed valve... which maybe where a new leak is I had the "Low Coolant" light on so I checked under the hood, I had enough coolant As I looked around I saw this: If you dont see pictures: http://community.webshots.com/myphotos?action=viewAllPhotos&albumID=476223273 Quote
5speedz34 Posted October 14, 2005 Report Posted October 14, 2005 Your leaking coolant, replace that little hose and put a gasket on the bleeder and you should be set. Quote
f_399 Posted October 14, 2005 Author Report Posted October 14, 2005 what are these parts called so i can purchase them? Quote
5speedz34 Posted October 14, 2005 Report Posted October 14, 2005 I would get both at the dealer, since that hose is pre-bent it will be hard to find a replacement but check at your local parts store. Quote
f_399 Posted October 14, 2005 Author Report Posted October 14, 2005 ok will check the dealer and a parts store is this caused by wear and tear or... did it happen when we took the radiator out? Quote
5speedz34 Posted October 14, 2005 Report Posted October 14, 2005 ok will check the dealer and a parts store is this caused by wear and tear or... did it happen when we took the radiator out? Probably just wear and tear, the hose looks old. Quote
THe_DeTAiL3R Posted October 14, 2005 Report Posted October 14, 2005 Strange how it's leaking in 2 seperate spots (it's not just dripping down from behind onto the bottem part is it?).. but yeah I agree with replacing that old hose and that bleeder gasket. Quote
f_399 Posted October 22, 2005 Author Report Posted October 22, 2005 I replaced the little tube (heater bypass?) and the clamps Is there fluid flowing through that tube constantly or only when the car hits a certain temperature? I want to check if I solved the problem or if its another leak Quote
