fergup Posted October 13, 2005 Report Posted October 13, 2005 Cant find anything in searches. I need to replace the various front suspension bushings on a 94 cutlass. I was thinking Urethane. Anyone know where to look for these. Thnx Quote
pwmin Posted October 13, 2005 Report Posted October 13, 2005 phew, got it in before you got impatient/pissed a/o locked from http://www.clubgp.com/newforum/tm.asp?m=2549907&p=1&tmode=1&smode=1 6. Front Poly Bushings - Front Swaybar Poly Bushings - Energy Suspention - FE3 Swaybar 23mm 9.5127 9.5115 - http://www.energysuspension.com/pages/swaybbct.html - inner bushing 9.5173G (1 3/8") greasable. i actually used 9.5160G for the outside (15/16" =24mm) but i guess i could have used 9.5159G (23 mm greasable) - i used 9.5158 for my addco bar outers so i could have greasable bushings, but i had to drill the holes bigger, whereas the fronts i did not. Quote
pwmin Posted October 14, 2005 Report Posted October 14, 2005 i used 9.5158 for my addco bar outers so i could have greasable bushings that is for the rear, not front. what other bushing? no motor mounts avail, poly dust boots for ball joints, no cradle mounts avail., cant think of any other bushings right now :oops: Quote
5speedz34 Posted October 14, 2005 Report Posted October 14, 2005 Sway bar, and control arm are the only ones up front. Rears would be lateral links and trailering arms. Quote
