J Posted October 11, 2005 Report Posted October 11, 2005 I noticed last time i was under the hood of my car that the bulkhead connector of the harness into the passanger side of the firewall is all fucking cracked and exposed. How in the hell can i fix this, without swapping a harness? I was thinking of disconnecting it from the firewall and then getting a piece of shrink wrap and shrink wrapping it, then some electrical tape then another layer of shrink wrap. WTF do i do? Thanks fellas Jay Quote
Guest TurboSedan Posted October 11, 2005 Report Posted October 11, 2005 i just went out to my garage so i could get a look at this plug (i have a junk 3.1/5-speed harness). the main firewall connector plug can easily be repinned. all you have to do is pull the blue plastic retainers out of the side of the plug, then gently pull the wires/connectors out of the plug. then find a good plug from a salvage yard and put the wires/connectors back into their respective slots and push the plastic retainers back into place. should be an easy fix. Quote
J Posted October 11, 2005 Author Report Posted October 11, 2005 good to know, thanks a million. Is that 3.1 5 speed harness junk or extra? Quote
Guest TurboSedan Posted October 11, 2005 Report Posted October 11, 2005 yeah it's fucked. there are ton of things wrong with it. Quote
slick Posted October 11, 2005 Report Posted October 11, 2005 Jay, I personally wouldn't worry about the current harness you have in your car IMHO. I would search for a good 3.1/5speed harness, and make sure that it's all in good condition. Quote
J Posted October 12, 2005 Author Report Posted October 12, 2005 ahh i just wanted the harness he had if it was good, mine is totally virgin and not hacked, just that bulkhead connector (i think i did that when i did my plugs when i was 17) Quote
sl3196 Posted October 12, 2005 Report Posted October 12, 2005 yeah it's fucked. there are ton of things wrong with it. The VSS wire is on my cavi right now! Quote
5speedz34 Posted October 12, 2005 Report Posted October 12, 2005 yeah it's fucked. there are ton of things wrong with it. You should see the harness on the 88 its terrible. It was orginally a 88 2.8 manual harness and it's on a 89 auto engine. How should I fix this? I would like to just replace the junk harness would a 2.8 89 auto work and then solder the manual parts in? (vss, reverse lights etc.?) Quote
