93 Grand Prix Posted September 21, 2002 Report Posted September 21, 2002 Could someone please tell me how to wire my headlights so that the low beams will stay on when I turn on the high beams? I do a lot of traveling at night and can't see nothing. Also where can I find good prices on some PIAA bulbs? Quote
Guest Anonymous Posted September 21, 2002 Report Posted September 21, 2002 JC Whitney sells a kit to keep the low beams on while the high beams are on. I'll look it up and let you know the price. Quote
per0781 Posted September 21, 2002 Report Posted September 21, 2002 My dad also does a lot of driving at night and would like to have his lows onwhile his highs are on. The info from jcwhitney would be greatly appreciated. Paul Quote
Guest Anonymous Posted September 21, 2002 Report Posted September 21, 2002 Here's the info on it... Works on 88-98 GM cars or trucks. Only 4 wires to hook up. Part # 81NU1821P - This is the # out of the brand new catalog. Part # 81UY1821P - This is the # out of the last catalog. Both part #'s bring up the same item on their website. Price $19.99 If anyone gets this let me know how it works. I'd like to try it on my TGP. Quote
no1kicker Posted September 21, 2002 Report Posted September 21, 2002 Would this draw a lot of extra current from the battery? Quote
GnatGoSplat Posted September 21, 2002 Report Posted September 21, 2002 This would be easy to do with a simple relay and relay socket. You can get both for less than $3 from http://www.partsexpress.com. On the bottom of the relay, the terminals will be labeled. #85 and #86 are the coil, #30 and #87 are the switch. Ground one end of the coil (#85) and connect the other end (#86) to the high-beam positive wire (LT GRN). Splice terminal #30 into the high-beam positive wire (LT GRN) and splice terminal #87 into the low-beam positive wire (TAN). What this will do: When high-beams are ON, the relay coil will energize, connecting terminals #30 and #87 together, therefore directing power going to the high beams to the low beams as well. I have not done this, but in theory it should work perfectly. Assuming the low-beams are normal 45W bulbs, this will consume 7.5A more current. Quote
MaD Posted September 23, 2002 Report Posted September 23, 2002 Hey, then on top of that, you could hook the relay up to a switch, so you can turn this "option" off when you just want the high beams -MaD- Quote
93 Cutlass Posted September 23, 2002 Report Posted September 23, 2002 Hmmm...my low beams stay on with the highs and I've never touched them. I did, however, wire the fogs to stay on with the highs/lows. That way I have all 6 light on at night. Talk about bright! Of course the 80 watt low and 100 watt high bulbs make a huge difference. Adam Quote
GnatGoSplat Posted September 23, 2002 Report Posted September 23, 2002 I think only cars with miniquads have the low-beams that stay on with the high-beams from the factory. My '94 does that too. Quote
93CutlassSupreme Posted March 7, 2008 Report Posted March 7, 2008 This would be easy to do with a simple relay and relay socket. You can get both for less than $3 from http://www.partsexpress.com. Which relay? Quote
GnatGoSplat Posted March 7, 2008 Report Posted March 7, 2008 This would be easy to do with a simple relay and relay socket. You can get both for less than $3 from http://www.partsexpress.com. Which relay? I don't really remember back 6yrs very well, but I think I must have been talking about this one. http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=330-073 Quote
rockfangd Posted March 8, 2008 Report Posted March 8, 2008 holy old thread buying a module is just a more expensive version of a relay lol Quote
