Trunk alignment issue? Coupe
Common problem?
How did you fix it?
I'm assuming its just readjusting the bolts.
Loosen the bolts on the hinge and the trunk will be able to move around.
I usually loosen it enough that it can move with some coaxing, but not too loose because it'll move around too much.
I discovered after aligning the trunk the best I could, that it was clear the taillights weren't aligned very well either, and then when I tried to align the taillights better, I could tell the reverse light wasn't well aligned, and neither is the bumper. The amounts are small, just 1/8" here, 1/8" there. A lot of it just couldn't be aligned perfectly. Mid-90's American cars definitely aren't good for someone as OCD as I am.
