badassoldspower Posted September 30, 2005 Report Posted September 30, 2005 Hey im about to put my intrax springs on my car, what macpherson strut compressor do you guys recommend to use, and where can i rent one of these tools? Quote
pwmin Posted September 30, 2005 Report Posted September 30, 2005 auto zone is probably the easiest to rent from. there are two styles. one that's one complete unit and one that has two pieces that you put on either side of the strut. wish i could describe them better. they'll probably have the latter. make sure you tighten them evenly. scribe or mark somehow how the old springs lined up so you know how to put them back in. you will most likely be confused. i def would get it aligned asap. Quote
GnatGoSplat Posted October 3, 2005 Report Posted October 3, 2005 I used a set of spring compressors that I got from Harbor Freight for $8 on sale. Cheap, but worked fine. The 1-piece would probably work better if you can get it. Quote
Jcrow Posted October 3, 2005 Report Posted October 3, 2005 I go tmine on ebay for $10. Its 2 clamps to go on either side of the spring. Worked great! I undid 3 nuts on strut tower, compressed both sides of spring, removed center strut nut, pry out rubber thing, unscrewed strut cartiridge from knuckle (needed PB blaster and torch on the other side). pulled spring right out. The new springs barely need compressing to get in! The rest is just reverse. Quote
ShockTherapy Posted October 3, 2005 Report Posted October 3, 2005 just rent from any auto parts store. Quote
badassoldspower Posted October 4, 2005 Author Report Posted October 4, 2005 thanks guys, ive got my car all lowered now, front and back ill get pics soon Quote
Pabz Posted October 7, 2005 Report Posted October 7, 2005 I Got mine springs in last night. Getting alignment done tuesday. I changed the outer tie rod ends so hopefully i didnt mess anything up. I used the counting method 18 turns off 18 turn to go back on. I can wait to drive it. :devil: This took 3 days, the first to were basically learning the process, i actually did the second strut tower in 5 hours. But my whole body hurts now, so time to rest. Pics soon to come. Birchmount on the back!!! Quote
