m0sh_man Posted September 28, 2005 Report Posted September 28, 2005 something tells me this isnt normal..... but when i turn my park lights on my DIC turns off, the lights for the buttons are still lit up, but the actual DIC screen goes blank..... i tried it without the headlights on, and just parklights, and like stated, it turns off with parklights. any idea's? matthew Quote
GutlessSupreme Posted September 28, 2005 Report Posted September 28, 2005 Did you install it yourself? Is your interior light dimmer switch off? Quote
Guest Anonymous Posted September 28, 2005 Report Posted September 28, 2005 Your DIC is really messed up. However, the VFD dimmer runs off of a couple of different wires... One could be messed up. In one instance, it gets its illumination power w/o the headlights on, but when the headlights are on, the power comes from the headlight pod. I just think your DIC is bad and should be replaced. Quote
m0sh_man Posted September 28, 2005 Author Report Posted September 28, 2005 it was factory in my car, i did not install it. anyone got one forsale, or can loan me to see if its just an issue with my DIC? matthew Quote
m0sh_man Posted September 28, 2005 Author Report Posted September 28, 2005 Did you install it yourself? Is your interior light dimmer switch off? where is the dinner switch located? its night time, and im not going out to the car at the moment to check it out Quote
TeeJay3800 Posted September 28, 2005 Report Posted September 28, 2005 All I can say about this is that my DIS turns off temporarily when I turn the parking or headlights on. It turns off (it actually just dims significantly) for maybe a second before it comes back on fully. Quote
digitaloutsider Posted September 28, 2005 Report Posted September 28, 2005 Sounds like either the dimmer or the unit itself. I'm sort of leaning on dimmer. Quote
RareGMFan Posted September 28, 2005 Report Posted September 28, 2005 Yeah, I say dimmer, too. I've also seen where the dimmer switch is at maximum, right before it turns on the interior lights, and for some reason, causes the DIC to go out. I can't remember if it was the TGP, or the TSTE that had this issue, but I moved the dimimer switch a HAIR, and it was back on at full force. But they ARE supposed to dim a tad when you first turn on your lights, just as your radio display does. Quote
jeremy Posted September 28, 2005 Report Posted September 28, 2005 anyone got one forsale I have a couple LCD ones that I currently have listed on eBay. PM me if you want the auction numbers Quote
no1kicker Posted September 28, 2005 Report Posted September 28, 2005 Try disconnecting the dimmer wire, that could be the problem like said above. Quote
Psych0matt Posted September 28, 2005 Report Posted September 28, 2005 where is the dinner switch located? between the lunch switch and the bedtime switch Quote
digitaloutsider Posted September 28, 2005 Report Posted September 28, 2005 where is the dinner switch located? between the lunch switch and the bedtime switch Quote
m0sh_man Posted September 29, 2005 Author Report Posted September 29, 2005 where is the dinner switch located? between the lunch switch and the bedtime switch i was waiting for someone to catch that... ok, my dimmer switch doesnt do a thing, so yes, i think its going bad, i tried to dim my lights, but i can move the switch all over the place,a nd they never change brightness, if i put it all the way up to int. lights, my map light comes on like normal. so im going junkyarding for a dimmer switch i guess. matthew Quote
