what size tank
would you recomend if i were to get one to use a paint gun to repaint my car(once confortable using it ofcourse).
im going ot buy a compressor kit and compressor.. just need recomended sizes for small time stuff.. like would 20gal. be enough? or for painting would i definatly need something more then 40gallon?
As big as you can possibly afford. You could probably make due with a 20 gal if you really had to, but if you can afford to go bigger... do it.
Depends apon the CFM rating of the gun you want to use....I'd recommend the bigger the tank the better...however it costs more$$$ as well, goodl uck!
Tough call, No matter what you get the compressors gonna be running almost the whole time. I'd do what the others have said. Go with the biggest that you can afford. 20Gs sounds ok, but I won't pay that. I would save up for the larger one because it would help in the long run with other projects anyhow. Might as well cough up for the larger ones since your mostly gonna use it more often then you think.
i found 2 im interested in
a $230 upright with a 4cfm at 90psi and a 330 with a 7cfm at 90 psi
would it be worth the extra 100 bux for that 3cfm difference?
