i have been having this problem with my car its a 94 z34. when i start it up its fine but when i put it into drive the abs light and e-brake light come on. i already checked the brake level. is there a brake level switch
well now when it is on all the time along with the red brake light. i have no idea what it could be. it all started to happen about 5 months ago then went a way and now it is on constant. i hate the little amber light
did u check the brake fluid level?
I know with me, My ABS light was on forever, then finaly the brake and ABS light are both on now.
My brake fluid is topped up also so I am stumped.
Why not pull the code and find out for sure?
Edit: is the ABS light BLINKING or steady??
First try tightening down your battery cables, especially the nut on the auxillary positive terminal. Next, be sure you don't have any blown fuses. There is one circuit (don't remember which one exactly) that if it blows the fuse, both the ABS and BRAKE lights light up...
I have a brand new battery in right now and I Checked the terminals there clean and tight. What fuse exactly should I be checking for this ABS light\Brake light.
i dont think it is a fuse. i tightened the nut down I will tell you if it worked it 10 min
should have a ABS relay, and two BIG fuses, at least that's how it is on mine
well its fixed for now. I hope. I forgot to put the fuse back in after tightening the nut. so we arer good now
