"Memory steer" likely causes?
After making a left turn, feels like it's pulling to the left. After making a right turn, feels like it's pulling to the right. Any worn suspension parts known to cause this? Had a 4-wheel alignment, tie rod replacement, and new tires, but this did not correct.
what was your caster spec after you did the alighnment.......
who did the alighnment?
you might have worn out bearing plates or a bad rack n pinion......
get back to me on this.....
My Lumina had some memory steer. The shop said I needed my strut bearing replaced (i think thats what he called it). Its fine now so I guess that was the problem.
that is the most common cause of memory steer..... but a bad rack/loose fron end parts can cause it, and caster being out of spec will cause the car to wonder and have memory steer.....
I had it on right turns only....it was the steering rack, the piston inside it wears out and odd things can happen like that
