1994 3.1 lumina euro rev limiter . map sensor, miss
Are rev limiters standaed on this car? If i open it up from idle in neautral it cuts out at 4000 rpm. also the rough idle and miss seem to be in the 750-1000 rpm range then it smooths out. in earlier post i described a clogged cat issue. could the map sensor be the cause of the miss and clogged cat????. when I tested the map, the voltage , key on , engine not running , it was 3.8 volts(within specs) but when i started it up it was suppose to increase by 1.5 volts .it didnt... and when i went wot it was suppose to increase to apox 4.5 volts , it actually dropped to about 1 volt. and if i have a bad o2 sensor or map or clogged cat shouldnt it be throwing codes?
They have a 4,000 rev limiter in Neutral, but nothing in Park.
IIRC: all of my w-bodys had a limiter in Park too :shrug:
.....you can have a bad or clogged cat with no codes
Wrong. The limiter is in park AND neutral.
Z34s have a limiter at 3000.
Older cars (90 and back) didn't have rev limiters, and manuals don't have a limiter either (at least not till redline in some cases).
THere is an in gear limiter, and a p/n limiter.
