Ticking noise
Supreme Cutlass
I've always had a clickity noise from the engine, and dismissed it as lifter tick. I went out with a screw driver to pinpoint the noise, and I heard the most noise from the fuel rails. Could the noise be from my injectors? or is this probably still lifter tick?
I'm really not familiar with how to do that :oops: ... could you give me a quick walkthrough?
It's your injectors ticking.
To ohm out the injectors, just take a multimeter, set it on reading ohm's, and go at it.
ive never heard injectors that you could hear ticking that loud... usualy you need a stethoscope to really hear the tick well in the first place. They have to be pretty bad to tick like that. you could hear the tick using the screwdriver trick, but from outside the car, wow
