gpse_97 Posted September 25, 2005 Report Posted September 25, 2005 hey gang how do I test the wheel speed sensors to see which one is causing my check ABS light? Can I use an Ohm Meter? thanks. Quote
jeremy Posted September 26, 2005 Report Posted September 26, 2005 The Ohm meter should do the trick for you. I really need to pick one up to test out the sensors on the Lincoln. :? Quote
