Guest RedCutlassSL Posted February 21, 2003 Report Posted February 21, 2003 My car is revving past 3 k in park, i know its not supposed to. Any ideas why? Oh and would someone mind coming to GB to wrench on me car, i'm too lazy to. Quote
Robby1870 Posted February 21, 2003 Report Posted February 21, 2003 Mine revs to 4K in park and then hits the rev limiter Robby Quote
Drache Rott Posted February 21, 2003 Report Posted February 21, 2003 hmm and I thought it was reving because you wont take your foot off the gas Quote
GnatGoSplat Posted February 21, 2003 Report Posted February 21, 2003 Sounds like an intake gasket leak. You can check for this by grabbing a can of carb cleaner (WD40 may work too) and spraying into the gasket. If the engine changes RPM or stutters when you do this, you have an intake gasket leak. VERY common problem with the 3.4 DOHC, and I think the 3100 has this problem too. Quote
lukee1982 Posted February 21, 2003 Report Posted February 21, 2003 If it isn't a gasket chech and make sure that everything is pluged in at your throtle body I had a problem with that. Quote
