Supreme Cutlass Posted September 24, 2005 Report Posted September 24, 2005 What id the best way to put two wires together? (interior use) I was wondering if twisting them together and wrapping them with electrical tape would work. Quote
Supreme Cutlass Posted September 24, 2005 Author Report Posted September 24, 2005 Sodder them or use a crimpable joint connector pretty half assed to twist them and then tape....... :| And thus, the reason I asked for a better way Soldering isn't that effective for interior use, so what's a crimpable joint connector?? Quote
Supreme Cutlass Posted September 24, 2005 Author Report Posted September 24, 2005 Ah, I know what you're talking about now.... I just forgot I had some in my kit When I solder in a small confined space I always find someway to burn myself... :oops: Quote
cutty Posted September 24, 2005 Report Posted September 24, 2005 heat shrink tubing works very good also Quote
GOT2B GM Posted September 24, 2005 Report Posted September 24, 2005 Solder then use heat shrink tubing Quote
Guest TurboSedan Posted September 25, 2005 Report Posted September 25, 2005 i use a Bernzomatic pen torch, a very small bit of paste flux, solder and then heat shrink tubing for any wiring connections i do. the Bernzomatic pen torch is great for wiring and works perfect on the heat shrink tubing too. the only time i've ever actually used a soldering iron on anything in my car was when i fixed the RKE module. the wiring for my gauges, HUD, stereo and engine wiring harness modification/repairs were all done with the pen torch. Quote
Crimson Fury Z Posted September 25, 2005 Report Posted September 25, 2005 pretty half assed to twist them and then tape....... :| Quote
J Posted September 25, 2005 Report Posted September 25, 2005 crimpable joint connector :| NOOOO garbage, just do it once and do it right, solder it Quote
Justin Posted September 25, 2005 Report Posted September 25, 2005 It really depends on the wire's location. If it's in a high flex location like a door boot soldering the wire will make it too brittle and it'll break. Most of the time it's the best, but not always. Quote
Redwingvksm Posted September 25, 2005 Report Posted September 25, 2005 It really depends on the wire's location. If it's in a high flex location like a door boot soldering the wire will make it too brittle and it'll break. Most of the time it's the best, but not always. Never have had that happen to me... I've ALWAYS solder it and than heatshrink. Black for ground red for power. I've NEVER had any problems with it being too brittle/not flexing enough/etc., just do it right and don't go down the whole wire... Quote
GnatGoSplat Posted September 26, 2005 Report Posted September 26, 2005 Yeah, keep the solder area small and it should flex just fine. Quote
