SaberZ Posted February 20, 2003 Report Posted February 20, 2003 to go back to the dealer. They replaced all 4 rotors on my impala. Looking at the work papers, i noticed them installing shims as well. Last time my breaks were done those weren't put on. I saw them add something to the front rotors(probably the shims) looked compact disc like. Dunno, any ideas what they are?, and what they do.? Thanks again for the support Quote
ctx46 Posted February 21, 2003 Report Posted February 21, 2003 those would be the shims..... GM had a problem with the slides sticking on the caliper because the caliper would bottom out on the slides and rust/corrod there..... so there fixe was to shim out both the rotor and the caliper hanger so they woudent bottom out....... BTW, hav you gotten the recall about your rack yet..... if not, you in for a treat.... Quote
SaberZ Posted February 21, 2003 Author Report Posted February 21, 2003 the recall? U mean the ISS? I had the lubricated twice. Never heard anything about rack and pinon stearing on it(tho i hear a clunk) but they never found out what it was. I hope u mean the iss, cuz i reallly dont want to go back there for awhile lol Quote
SaberZ Posted February 21, 2003 Author Report Posted February 21, 2003 Well I checked the NHTSA's website for any recall info, and nothing for the impala cept for the 3.4 engines. Quote
ctx46 Posted February 21, 2003 Report Posted February 21, 2003 I believe it effected impallas but it must not yet.... any ways, the customer compliant is a clunk in the fron end while turning and the steering wheel sticks in sharp cornering...... GM's fix was to replace the rack n' pinion, but if you just checked it out, it must not effect you "YET" later joe Quote
BXX Posted November 26, 2008 Report Posted November 26, 2008 The shims are actually used to correct runout due to excessive runout of the hub assembly mating surface. Without it, it would feel like you have warped rotors.. Quote
