nebojsa_o Posted September 20, 2005 Report Posted September 20, 2005 So my muffler burned out slowly, and at a J/Y I found a 3.4L CS coupe. Had decent looking mufflers, and they were dirt cheap, because I know the guy, and he was in a good mood. Either way, I took the 2 mufflers, and the Y-pipe, and slapped it on my 3100. Everything is stock GM parts. except now I have 2 mufflers from a 3.4L and a Y-pipe. I drove the car around for a bit, it doesn't make any unusual sounds like the other one did. But what happened to performance, did I lose power by doing this?? I can't really feel a difference, but it might be a tad slower, although it could be in my head, because I read about back pressure today, and now I'm confused, lol. I'm wondering would it lose a lot of back pressure because I did this, or should it act the same as it was with just a single GM muffler. Anyways, its only a temporary fix, if all goes well I'll be doing some true exhaust work in the spring/summer. But do you think I would lose power by doing this?? Seems to be the same to me, but then sometimes I think it might be slower... Although I floored it and went with first gear for a bit, and when it shifted to 2nd it chirped the tires. Not sure if it will do it again, or was it a coincidence of some sort, but I thought it was interesting. Quote
cutty Posted September 20, 2005 Report Posted September 20, 2005 yes it makes them loose power my cutty i had y-piped to two flows and it felt like i lost alot of power also, but right now i have a straight pipe, since the y-pipe rusted out. Quote
nebojsa_o Posted September 20, 2005 Author Report Posted September 20, 2005 Broke which way, I'm not feeling the loss, or the loss isn't there?? Or if you're talking about bank account broke, you got her!!!!! Quote
