rshissler Posted September 19, 2005 Report Posted September 19, 2005 How did u guys that built ur own boxes cut the holes for ur subs? my subs didn't come with any kind of pattern to cut trace and cut out like my 6x9s did and i cant find anything about the measurements to cut them. Quote
stockgp Posted September 19, 2005 Report Posted September 19, 2005 your cut-outs should be about 11 1/4" Quote
J Posted September 19, 2005 Report Posted September 19, 2005 flip the subs over and measure them and then draw a circle, drill a hole with a drill anbd then use a saw. It's goes pretty easy Remember measure 3 times, cut once Quote
Puggsley456 Posted September 19, 2005 Report Posted September 19, 2005 I think your subs have a 11" mounting diameter. But All I did to make the circle is take a scrap of wood and drill two holes in it that are exactly 1/2 of the diameter of the mounting hole you require, apart. One for the pivot point(screw) and one for the pencil to draw circle. And ancor it to the exact center of the front of the box using the screw. then using the homemade jig create your circel and cut it out. Quote
Garrett Powered Posted September 19, 2005 Report Posted September 19, 2005 the way I do it is take a pen and draw around the speaker. then measure the width of the screw hole ring. Now take that measurement and measure that 1/4" or whatever in from the ring making marks then connect the dots. Quote
