Stevo Posted September 17, 2005 Report Posted September 17, 2005 GP hood vents on a Cutlass .... Has anyone done it? Is it do-able? Quote
nebojsa_o Posted September 17, 2005 Report Posted September 17, 2005 I was thinking about that too. I'm sure it's doable, but I didn't see pics of anyone that has done it.. I'm able to get some of those too, but then again, how useful would they be?? Quote
Justin Posted September 17, 2005 Report Posted September 17, 2005 http://jeepforum.com/forum/showthread.php?t=141709&highlight=grand+prix http://oman4x4.com/hoodventinstall.htm Quote
Guest Anonymous Posted September 17, 2005 Report Posted September 17, 2005 Yes, some high end Jeeps and/or Cherokees got nearly identical hood vents to the 94-6 style. Yes, you can add them. Its simply a matter of cutting precise openings in your hood and correctly attaching the vents. Quote
BurneroftheRice Posted September 17, 2005 Report Posted September 17, 2005 The stock hood louvers on a Grand Cherokee. These were only offered on a 98 Grand Cherokee Limited with the 5.9 liter engine. I worked with a guy who had a grey one of these. I was always amazed how Dodge almost completely copies the design of the 94-96 GTP hood louvers. Dunno if you can make them heat extractors or not like the Z-34 or GTP louvers. Quote
mfewtrail Posted September 17, 2005 Report Posted September 17, 2005 The stock hood louvers on a Grand Cherokee. These were only offered on a 98 Grand Cherokee Limited with the 5.9 liter engine. I worked with a guy who had a grey one of these. I was always amazed how Dodge almost completely copies the design of the 94-96 GTP hood louvers. Dunno if you can make them heat extractors or not like the Z-34 or GTP louvers. Are one of those louvers in that picture turned backwards(the one on the left looks like it's turned to take air into the hood while the one on the right appears to be turned the opposite way)? Quote
Guest Anonymous Posted September 17, 2005 Report Posted September 17, 2005 Not to stray from topic, but cherokees also received an info center that was pretty similar to the 91-3 Grand prix one. But the concensus is yes, it can be done with the vents. Quote
Prospeeder Posted September 17, 2005 Report Posted September 17, 2005 The stock hood louvers on a Grand Cherokee. These were only offered on a 98 Grand Cherokee Limited with the 5.9 liter engine. I worked with a guy who had a grey one of these. I was always amazed how Dodge almost completely copies the design of the 94-96 GTP hood louvers. Dunno if you can make them heat extractors or not like the Z-34 or GTP louvers. Are one of those louvers in that picture turned backwards(the one on the left looks like it's turned to take air into the hood while the one on the right appears to be turned the opposite way)? ur right,t hats strange Quote
mfewtrail Posted September 17, 2005 Report Posted September 17, 2005 ur right,t hats strange Only thing I can think of is that the airbox/filter is located under that left side vent so they have it turned to pull air in instead of extract the air from the engine bay. I suppose they could have removed and reinstalled them without paying much attention to how they were turned as well though... Quote
Dirty Rockstar Posted September 17, 2005 Report Posted September 17, 2005 SOO weird.. Ive been tossing this idea around myself.. Im wanting them for my Oldsmobile.. I was thinking the curveature of them would fit with the car better than Z34 ones.. Quote
digitaloutsider Posted September 17, 2005 Report Posted September 17, 2005 [coughs].. http://www.w-body.com/forum/viewtopic.php?t=33408 Quote
JNGTP94 Posted September 17, 2005 Report Posted September 17, 2005 its doable but i would think the z34 ones probably would look way better -Edit Quote
nebojsa_o Posted September 17, 2005 Report Posted September 17, 2005 I think stevezasycho is saying that these would look better than the Z34 ones, not the other way around. I'm not sure if any would look good on a cutty sedan, because it just doesn't have as aggresive looking headlights, and they might look out of place. Quote
Guest Anonymous Posted September 17, 2005 Report Posted September 17, 2005 I don't think that the cherokee's hood vents are inverted. If you look closely at the picture, it just looks like a lighting glitch. I saw one once, and i think i would have picked up on the inversion as I was studying the vents very closely. Quote
streetdreams Posted September 18, 2005 Report Posted September 18, 2005 the ford escort cosworth was the originator for those hood scoops boys, were just biters like the cherokee camp as well man. anything is doable man its called fiberglass Quote
digitaloutsider Posted September 18, 2005 Report Posted September 18, 2005 Um. Fiberglass isn't really required for this.. Quote
Stevo Posted September 18, 2005 Author Report Posted September 18, 2005 I think I like the Z34 ones better than these... or prefer the earlier GP ones. Bigger is better in my opinion. Quote
Dirty Rockstar Posted September 19, 2005 Report Posted September 19, 2005 Im goin down to my Z34 hood and vents tomorrow, so I think Ill bring my digi cam, and see how the Z vents look on my Cutlass, and post them here for all to see.. 8) Quote
Dirty Rockstar Posted September 25, 2005 Report Posted September 25, 2005 Bump-dizzle; Okay, I laid my Z34 vents on my hood tosee how they look.. Im not sure whether I like it or not.. I think I would need a set of GTP/TGP vents to test out here.. Here they are: Lets hear what yall think.. 8) Quote
nebojsa_o Posted September 25, 2005 Report Posted September 25, 2005 I don't actually mind how that looks too much. Better than I imagined anyways. Quote
fastbird232 Posted September 25, 2005 Report Posted September 25, 2005 I agree. I think those will look better than GTP/TGP vents. Quote
nebojsa_o Posted September 25, 2005 Report Posted September 25, 2005 Well those don't look as good because they are different, and on a different Cutlass. The one Steve posted looks better than this one. Quote
Prospeeder Posted September 25, 2005 Report Posted September 25, 2005 I disagree. those looks way better, i like them Quote
GutlessSupreme Posted September 26, 2005 Report Posted September 26, 2005 Saw something interesting today.. that link that was posted earlier, with the GP-style vents on Grand Cherokees? I saw one for the first time today. Just thought it was weird because I had just read the topic a few days ago and suddenly I see the my first one ever.. I didn't really thing they looked that good.. too small, and not very well placed. Quote
