gpse_97 Posted September 16, 2005 Report Share Posted September 16, 2005 my brake light\parking break light is on. The E-brake is off, and I have brake fluid topped up. Any idea's??? what else would set the light off? Quote Link to comment Share on other sites More sharing options...
terryk2003 Posted September 16, 2005 Report Share Posted September 16, 2005 could be a bad fluid level sensor in the resevoir...also, is the pedal spongy with the car off?...have you checked for leaks?... Quote Link to comment Share on other sites More sharing options...
havikx Posted September 16, 2005 Report Share Posted September 16, 2005 it coudl be the sensor for the pedal position. definatly a sensor though. Quote Link to comment Share on other sites More sharing options...
THe_DeTAiL3R Posted September 16, 2005 Report Share Posted September 16, 2005 If your ebrake is stuck at all in any way that could be the problem. Try Putting the e-brake on HARD a bunch of times and see if that losens it up. Then check your rear brakes. Quote Link to comment Share on other sites More sharing options...
gpse_97 Posted September 16, 2005 Author Report Share Posted September 16, 2005 I will check teh rear brakes for sure, Its not the ebrake as I played with the sensor that controls that with no luck. My brake pedal feels normal also. I think the sensor in the resevoir is fubared. Quote Link to comment Share on other sites More sharing options...
