SEiZe Posted February 18, 2003 Report Posted February 18, 2003 I just want the retarded nozzle on the passenger side wiper to work correctly. Right now it squirts unlike the driver's side that sprays. Anyway to correct this? Quote
GnatGoSplat Posted February 18, 2003 Report Posted February 18, 2003 You can buy a new nozzle kit from GM. I think it's around $8/each. The type on the hood aren't newer, just different. GM doesn't usually use those. They're usually an import thing. I don't know which is better, I personally prefer the wiper mounted ones as the bumps on the hood look ugly. I had trouble with the hood mounted ones on the '86 Saab I used to drive too. Quote
SEiZe Posted February 18, 2003 Report Posted February 18, 2003 Do you have a part number for the new noozles ? Quote
91CuttyConv Posted February 18, 2003 Report Posted February 18, 2003 I would also recomend against the hood mounted ones, they get clogged very easy from wax and other things. The GM replacements are most likely your best bet. Jason Quote
GnatGoSplat Posted February 19, 2003 Report Posted February 19, 2003 Do you have a part number for the new noozles ? To fix your foozled noozle, you'll need part # 22094728. Quote
godofthunder Posted February 19, 2003 Report Posted February 19, 2003 A-bodies had em. On my ciera and our current century, their kinda hidden in the vents b/t the hood and windshild. Seize, I have the same problem! I need to get out and clean them both. The pass. one though had come somewhat loose, and wasnt holding on good to the wiper. I got part of it back on, but havent had enough time to really get it on good. Shawn, whats all included? Jon Quote
