Molding around windshield loose
The molding around my windshield is loose around the outside edges, what is a good way to fix this??
If you're talking about the vinyl molding, Permatex Adhesive Clear Silicone should fix you right up. When it cures, it becomes VERY strong.
If you're talking about the metal pieces, they're attached using phillips screws and you should be able to tighten them up if they're loose.
