How do you reset the DIC on a 91 GTP
my DIC is always in-correct, ive never tried to correct it, and im not even 100% its a good unit,
does anyone have a writeup on how this thing is reset?
That is the best quote EVAR!!!!!!!!!!!!!
Guest Anonymous
If you are asking about the Compass, press the calibrate button and drive around in a circle 3 times doing 5MPH until it says CAL SET then it will say N SET, and point the car due north and press the NORTH button.
As far as service reminders go, press the SYSTEMS CHECK and when the desired service comes up, press and hold RESET and then you have the option to eneter the desired mileage code. If you want to reset your avg. speed or econ, select them and hold down RESET.
my stuid Check Fuel thing on Range is on, its pissing me off, and it wont reset! i have 3/4 of a tank, and no Check fuel on the gages or nothin, stupid DIC, it just started doing it
Guest Anonymous
Mine does that too....
