93GTP Posted September 15, 2005 Report Posted September 15, 2005 I'm wondering if I can run higher than stock oil pressure by shimming or swapping out the pressure regulator spring in the oil pump? Or if it is even advisable to do that? I know I've seen the guys on Horsepower TV do it a few times with LS1's and other engines as well. Does anyone have any insight/experience/knowledge to share regarding this? Quote
manitcor Posted September 15, 2005 Report Posted September 15, 2005 what advatnage do you hope to gain by increasing the oil pressure? Quote
94CutlassSLCoupe Posted September 15, 2005 Report Posted September 15, 2005 i agree with manticor...higher pressure is only just that much more drag on the engine. Quote
Dan94Z34 Posted September 15, 2005 Report Posted September 15, 2005 If you put a high pressure pump you may blow one or more of your gaskets out. They arn't designed to hold back the pressure the pump puts out. Found that out on a 350 I rebuilt. I put a high pressure pump in it and stock cork gaskets. About a week after I got it done, I blew the rear main out of the car. The rear main completly came out. Talk about a major oil leak! A buddy of mines dad rebuilds old school chevy v8's all the time. He just uses the stock oil pump. He says there is no reason to have a high pressure pump. Also with a high volume pump and a stock oil pan, you run the risk of sucking the pan dry. Air doesn't lube very well the last time I checked. Quote
