BlackMagic859 Posted September 14, 2005 Report Posted September 14, 2005 Ok i've been wondering what would be better for my GP just installing a Shift kit, or changing to a standard, My dad was into drag racing back in the days of muscle and tells me that a shift kit would probably be better for my car considering im only getting into drag racing, but a lot of people tell me i should swap Quote
Psych0matt Posted September 14, 2005 Report Posted September 14, 2005 for the money, shift kit. 5 speeds are hella more fun, but its gonna cost ya. for the strip a kit should be pretty good too. Quote
jeremy Posted September 14, 2005 Report Posted September 14, 2005 Automatics are more consistant in the 1/4 mile if you end up bracket racing. Quote
gpse_97 Posted September 14, 2005 Report Posted September 14, 2005 what company makes a shift kit for the 4T60-E? Quote
THe_DeTAiL3R Posted September 14, 2005 Report Posted September 14, 2005 I agree shift kit would be better suited for the 1/4 mile. Some engines may bennefit from having a manual (ie 2.8 in the older w-bodies were like low 17 with 5-speed and around 18 w/auto.) but some like the 3.4DOHC it doesn't seem to matter much. Quote
BlackMagic859 Posted September 14, 2005 Author Report Posted September 14, 2005 Right now with my automatic as it is i was hitting high 17's so how much of a difference would a shift kit make? Quote
THe_DeTAiL3R Posted September 15, 2005 Report Posted September 15, 2005 I see in your profile you have a 93 GP 3.1 ... Personally with that I would go for a stick to gain some speed in 1/4 mile. I don't know about others here but I believe having the extra gears will get you in the low 17s with that engine. 3.1s just don't have top end so autos kill performance.. A shift kit *might* give you a tenth or something, not a whole lot. But really the question you should be asking yourself is what you really want to achieve by taking your car to the track. I know what it's like to get spanked constantly in the 1/4 mile, and unless you turbocharge it or something maybe you should consider a different car before spending all the money into a 5-speed swap. That being said a shift kit might be best for your wallet. Quote
Bossman429 Posted September 15, 2005 Report Posted September 15, 2005 I think B&M makes a "shift Improver" for the 4T60-E. Check Summit Racing, I think I've seen em there. Found it: http://store.summitracing.com/default.asp?target=partdetail.asp&autofilter=1&Ntt=trans+shift&N=4294822072+4294846070&part=GRN%2D420105&autoview=sku&Ntk=KeywordSearch I'd give that a try and see if you like it, if not, then sell it to some sucker on the board and swap to a 5 speed. Quote
pwmin Posted September 15, 2005 Report Posted September 15, 2005 so that would be a 4t60 (th125 or whatever)? if so, a shift kit would probably be beneficial. if it's electronically controlled, forget it. shift kits dont do much if anything. i wouldnt do a manual swap. i would do the shift kit (if its not electronically controlled) and just get the best time you can and bracket race it to get consistent and then get a faster car if you even like drag racing or do an L67 swap. you might get tired of drag racing. don't know why, but it's possible. i voted for a 5speed swap, but i retract it. i didnt read the post first. :alcoholic: Quote
BlackMagic859 Posted September 15, 2005 Author Report Posted September 15, 2005 as far as i know the kit im looking into isn't electronic, its supposed to go directly into the transmission Quote
gpse_97 Posted September 16, 2005 Report Posted September 16, 2005 ya an electrical shift kit isn't worth it for me. I wounder if we can shim the Shift Accumulators like on the 4T65-E. Quote
sonyman87 Posted September 16, 2005 Report Posted September 16, 2005 I think B&M makes a "shift Improver" for the 4T60-E. Check Summit Racing, I think I've seen em there.Found it: http://store.summitracing.com/default.asp?target=partdetail.asp&autofilter=1&Ntt=trans+shift&N=4294822072+4294846070&part=GRN%2D420105&autoview=sku&Ntk=KeywordSearch I'd give that a try and see if you like it, if not, then sell it to some sucker on the board and swap to a 5 speed. never seen that one. maybe that would help my trany. Quote
digitaloutsider Posted September 16, 2005 Report Posted September 16, 2005 If you have a 88-93 Grand Prix and a 2.8/3.1, just swap in a 5-speed. It's practically plug and play.. The hardest part is mounting the clutch pedal. Quote
BlackMagic859 Posted September 17, 2005 Author Report Posted September 17, 2005 If you have a 88-93 Grand Prix and a 2.8/3.1, just swap in a 5-speed. It's practically plug and play.. The hardest part is mounting the clutch pedal. How much would the swap cost Quote
digitaloutsider Posted September 17, 2005 Report Posted September 17, 2005 As much as you can get the parts for. It can be done as cheap as $300. Hell you can buy a 5-speed parts car for that and have everything you need. Quote
93CutlassSupreme Posted September 17, 2005 Report Posted September 17, 2005 i didn't vote because if you're serious about drag racing, you wouldn't be doing it in a w-body Quote
sl3196 Posted September 17, 2005 Report Posted September 17, 2005 i didn't vote because if you're serious about drag racing, you wouldn't be doing it in a w-body Then why post? Quote
Psych0matt Posted September 17, 2005 Report Posted September 17, 2005 i didn't vote because if you're serious about drag racing, you wouldn't be doing it in a w-body Then why post? Because he's got a good point. Quote
sl3196 Posted September 17, 2005 Report Posted September 17, 2005 i didn't vote because if you're serious about drag racing, you wouldn't be doing it in a w-body Then why post? Because he's got a good point. Not really.. Quote
THe_DeTAiL3R Posted September 17, 2005 Report Posted September 17, 2005 What about Zoomer's 9second turbo+supercharged Grand Prix? Quote
BlackMagic859 Posted September 17, 2005 Author Report Posted September 17, 2005 i didn't vote because if you're serious about drag racing, you wouldn't be doing it in a w-body no im sure i won't be doing professional drag racing with my grand prix but im not gonna walk the same road as everyone else and buy a civic or dip into my pockets and try to buy a muscle car not that i don't like either but i prefer the road less Traveled anybody can buy one of the cars above but i myself choose to be different Quote
93CutlassSupreme Posted September 18, 2005 Report Posted September 18, 2005 i didn't vote because if you're serious about drag racing, you wouldn't be doing it in a w-body Then why post? Because he's got a good point. Not really.. most of our cars run what, a 17 second quarter? Dan, even your GTP ran what, a 15 stock? these arn't exactly fast times. hell, i could pick up a 15 year old Mustang 5.0 for under a grand and run the quarter as fast as a stock L67, and then if i wanted more speed i could work on it, but i'd still be ahead because i paid less for the car and 302 parts are cheaper than any comparable parts in the w-body aftermarket i'm not saying w-bodies are junk, because they are not, but it isn't wise to create a w-body drag car Quote
sl3196 Posted September 18, 2005 Report Posted September 18, 2005 Last time I checked this is a w-body enthusiest site. Quote
Guest TurboSedan Posted September 18, 2005 Report Posted September 18, 2005 i didn't vote because if you're serious about drag racing, you wouldn't be doing it in a w-body Then why post? Because he's got a good point. Not really.. most of our cars run what, a 17 second quarter? Dan, even your GTP ran what, a 15 stock? these arn't exactly fast times. hell, i could pick up a 15 year old Mustang 5.0 for under a grand and run the quarter as fast as a stock L67, and then if i wanted more speed i could work on it, but i'd still be ahead because i paid less for the car and 302 parts are cheaper than any comparable parts in the w-body aftermarket i'm not saying w-bodies are junk, because they are not, but it isn't wise to create a w-body drag car knock it off Kevin. we've heard this same shit from you before you are full of it. they may be slow *stock* but we can do things to these cars that can hardly be considered "slow". you keep it up i delete your posts. Quote
