z34_nut Posted September 13, 2005 Report Posted September 13, 2005 I cannot for the life of me, find that damn grommet on the firewall. I can't find it on the inside of my car either. WTF? I am not resorting to mutalting the firewall on my car. Is there any other way to run the power wire in any other spot in the firewall? Seriously, I've got everything wired up, and then the last thing I need to do for wires, this gets in the way. Does the fact that is a standard matter? I wouldn't think so, because the standard shouldn't effect the firewall. ~Fustrated. Quote
z34_nut Posted September 13, 2005 Author Report Posted September 13, 2005 I'll try looking again, but the clutch fluid container is right there on a 5-speed, perhaps thats why its not there? who knows. thanks Jeremy. Quote
jeremy Posted September 13, 2005 Report Posted September 13, 2005 I'll try looking again, but the clutch fluid container is right there on a 5-speed, perhaps thats why its not there? who knows. thanks Jeremy. I just realized that there was something else mounted there on 5spds..... Quote
DiscoStudd Posted September 13, 2005 Report Posted September 13, 2005 Uh-oh, looks like we better put that pic (of my car) up in the FAQ section ! If you have a 5-Speed, then you won't have the grommet, because that's where the clutch master cylinder passes through the firewall... Quote
jeremy Posted September 13, 2005 Report Posted September 13, 2005 Uh-oh, looks like we better put that pic (of my car) up in the FAQ section ! If you have a 5-Speed, then you won't have the grommet, because that's where the clutch master cylinder passes through the firewall... That might be a good idea. Has anyone with a 5spd actually been able to find another hole in the firewall. I don't think Kevin ever found one Quote
z34_nut Posted September 13, 2005 Author Report Posted September 13, 2005 oo man, I definatly don't want to do any drilling today. Michael had a power cord in this car prior, I'll have to call him. I'll post the results. Quote
z34_nut Posted September 13, 2005 Author Report Posted September 13, 2005 Does any-one know where the power + from the bose system comes in? I could use that, take the old cord, and pull the 4 gauge through. Quote
z34_nut Posted September 13, 2005 Author Report Posted September 13, 2005 good news, found a hole on the drivers side. Its just big enough for my 4 gauge, but don't expect to run anything bigger. As for the location, its just under the steering shaft form in the firewall, almost behind the brake pedal. It took some peeling of the carpet, but I found it. Quote
LukeZ34 Posted September 13, 2005 Report Posted September 13, 2005 Bose power is in the main harness at the bose amp, and I'm pretty sure the wires for it are wrapped with the other wires that lead to the trunk. I had the same problem as you and just drilled a hole in the firewall then ran the wire down the drivers side and in to the trunk. Quote
slick Posted September 14, 2005 Report Posted September 14, 2005 Be sure to put a grommet in the firewall. Don't need those nice new amps of your's frying anytime soon. Quote
J Posted September 14, 2005 Report Posted September 14, 2005 leanred that the hard way when i was 16, no grommet, coated wires don't like to rub on sharp edges of firewalls very much :oops: Quote
z34_nut Posted September 14, 2005 Author Report Posted September 14, 2005 Yeah, thats the thing, it had a great rubber grommet on there, so, I put the 4 gauge right in. Quote
