Supreme Cutlass Posted September 13, 2005 Report Share Posted September 13, 2005 My dummy lights aren't working... what's wrong? Note: I have a UB3 installed. Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 14, 2005 Author Report Share Posted September 14, 2005 bump Quote Link to comment Share on other sites More sharing options...
GP1138 Posted September 14, 2005 Report Share Posted September 14, 2005 "Patient: Gee doc, my stomach hurts, what could it be?" Ugh, I was gonna write something witty here, but just tell us what happened before your dummy lights stopped working. PS. Your statement about installing UB3 could be the problem, are you absolutely 100% cut-off-your-dick if you're wrong sure that you wired it correctly and that all bulbs are functional???? Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 PS. Your statement about installing UB3 could be the problem, are you absolutely 100% cut-off-your-dick if you're wrong sure that you wired it correctly and that all bulbs are functional???? Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 14, 2005 Author Report Share Posted September 14, 2005 DAMN sure the bulbs work, ... wouldn't bet my dick on the wiring... what color wire would I have messed up and what spot does it go in? I know I had a solid white one that wasn't in the w-body.com write-up... Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 you could have messed up a few of them if NONE of the lights work Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 14, 2005 Author Report Share Posted September 14, 2005 I couldn't have just messed up a ground? Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 14, 2005 Author Report Share Posted September 14, 2005 :?: Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 no Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 you could have messed up the ignition power to the bulbs, though. the bulbs don't have their own ground. they are grounded when the ecm or other sensors send them a signal Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 14, 2005 Author Report Share Posted September 14, 2005 Looking at the diagram, I should have a pink/black wire in C15 that supplies the juice for the lights, correct? Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 no. what diagram are you looking at? c15 should be empty Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 14, 2005 Author Report Share Posted September 14, 2005 Page 8A--81-2 Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 oh you have a fsm. look at the diagram in the upgrade section of the w-body main page. if you got that one wrong, you may have other wrong as well Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 C1 (PNK/BLK) Ignition power to Cluster. Battery voltage in RUN, BULB TEST or START. See schematic 8A-11. C2 (LT BLU 14) To Left Turn Indicator. Flashing battery voltage with Left turn signal. 0 volts with signal off. See Schematic Section 8A-110. C3 (DK BLU 15) To Right Turn Indicator. Flashing battery voltage with Right turn signal. 0 volts with signal off. See Schematic Section 8A-110. C4 (TAN/WHT 33) To BRAKE Indicator. Indicator is grounded when Park Brake is on or Brake Fluid Level is low. Infinite ohms with Park Brake off and system OK. See Schematic Section 8A-41. C5 (GRY/WHT 852) To ANTI-LOCK Brake Indicator. See Section 8A-44. C6 (TAN/BLK 456) To Shift Indicator. ECM provides a ground when car is to be shifted. See Section 6E of the Service Manual. C7 (LT GRN 11) Hi Beam Indicator. Battery voltage when Hi Beams are on. 0 volts with Hi Beams off. See Schematic Section 8A-100. C8 NOT USED C9 NOT USED C10 (YEL 726) Display Dim Enable. Battery voltage when Park Lights are on. 0 volts with Park Lights off. See Schematic Section 8A-114. C11 (GRY 8) To Cluster Illumination bulbs. Variable voltage with Head or Park lights on and Dimmer Control adjusted. C12 NOT USED C13 (ORN 461) Bi-directional Serial Data Link between Cluster & ECM. C14 (BLK/WHT 151) Ground to G101. See 8A-14. C15 NOT USED C16 (PNK/BLK 750) Ignition power to Cluster. Battery voltage in RUN. See 8A-11. Terminals D1-D16 Terminal-Wire Color Function D1 (BLK 150) Ground. See Section 8A-14. D2 (YEL 237) Safety Belt input from Component Center. Battery voltage for 5 to 10 seconds after Ignition is put in RUN. D3 (YEL/BLK 68) LOW COOLANT Indicator input. See Test L, M D4 (BRN 25) CHARGE Indicator input. See Schematic Section 8A-30. D5 (BRN/WHT 419) SERVICE ENG. SOON input from ECM. See Section 6E of Service Manual. D6 NOT USED D7 NOT USED D8 NOT USED D9 (LT BLU 811) English/metric switch output. See test N. D10 (BRN/WHT 230) VF Dimmer input. Variable voltage with lights on and dimmer adjusted. See 8A-114. D11 (TAN 31) Oil Pressure input. Sender resistance varies from 15 ohms, low pressure, to 91 ohms, high pressure. Tests E, F, G. D12 (DK GRN/WHT 35) Coolant Temperature input. Send resistance varies from 60 ohms, hot, to 1500 ohms, cold. Tests H, I, J. D13 (PPL 30) Fuel Level input. Sensor resistance varies from 18 ohms, empty, to 88 ohms, full. Tests B, C, D. D14 NOT USED D15 (DK GRN 389) Vehicle Speed input from ECM. See Schematic Section 8A-33. D16 (ORN 640) Battery power (memory) to Cluster. Battery voltage at all times. See Section 8A-11. Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 14, 2005 Author Report Share Posted September 14, 2005 I'm looking at the walkthrough on the site, and apparently C15 (the hot wire for the dummy lights) is left un-connected... so... how do they get power in the first place? I don't see anything on the UB3 wires you listed that gives the power for them to light up, I see grounds but no 10 AMP input. Am I missing it? Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 did you read the whole walkthrough? because it specifically says the procedure is to go from the base digi to gages cluster. that means you completely disregard the first set of pinouts, since you have a 92+ analog cluster. the pinouts i listed are the correct pinouts for the ub3 cluster. you have to look at the pinouts for your 92 cluster and figure out which wire is power to the bulbs. i don't have the diagram in front of me so i can't tell you Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 14, 2005 Author Report Share Posted September 14, 2005 Ah, I thought the "Gauges" diagram was for the UB3, not the analog thing. And yes, I disregarded the first pinouts, hence the fact that the UB3 works . Where can I find the diagram for a UB3? Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 the pinouts i listed are the correct pinouts for the ub3 cluster. Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 14, 2005 Report Share Posted September 14, 2005 if that's th case, how did you get that c15 should be ignition power? Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 14, 2005 Author Report Share Posted September 14, 2005 What I meant was, I was looking at the diagram for the analog cluster, thinking it was for the UB3 because it said "Gauges" on the top :oops:. But i'm still confused as to how those bulbs get power if you disregard the wire that gives them 10 amps. Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 15, 2005 Report Share Posted September 15, 2005 ok i got my diagrams. i see where why you thought c15 was right. before i do any more, did you have a full gague cluster, or just a speedo and dummy lights? Quote Link to comment Share on other sites More sharing options...
stockgp Posted September 15, 2005 Report Share Posted September 15, 2005 never mind it doesn't matter. the wire you had in c15 goes to c1 Quote Link to comment Share on other sites More sharing options...
Supreme Cutlass Posted September 15, 2005 Author Report Share Posted September 15, 2005 Thank you! Quote Link to comment Share on other sites More sharing options...
