LukeZ34 Posted September 14, 2005 Report Posted September 14, 2005 Sounds like that behaves exactly like mine did. I've also got the same bucking problem, so it's certaintly something in the ECM that's not right. Quote
TGPilot Posted September 14, 2005 Report Posted September 14, 2005 Only problem with A/F tied to the ECM/stock 02 sensor is that it is showing you what the ECM thinks it sees...not actual. A true stand-alone wideband 02 is the way to see what is actual. Didn't setting the VSS to display correct speed cure the bucking issue? 8) Quote
Guest TurboSedan Posted September 14, 2005 Report Posted September 14, 2005 Only problem with A/F tied to the ECM/stock 02 sensor is that it is showing you what the ECM thinks it sees...not actual. A true stand-alone wideband 02 is the way to see what is actual. well, it does and it doesn't. it's not telling me the A/F, but it is telling me that it is in closed loop during light decel, which definately is not right. whether it is in closed loop during light decel because of the VSS i am not sure yet. people say that a narrowband A/F gauge is useless but i disagree. it's not a useful tuning tool, but it's a great diagnostic tool IMO. Quote
Guest TurboSedan Posted September 26, 2005 Report Posted September 26, 2005 I'm curious how your A/F gauge reads on your car when you get it hooked up. I want to see if it's anything like mine. i've only gotten one vid that turned out: http://www.turbosedan.com/vids/MOV02357.MPG that was starting at about a 40mph cruise in 3rd gear then WOT. the 2nd to the last green light was dimmly lit up but you can't really tell in the vid. Quote
