jwagner166 Posted September 11, 2005 Report Posted September 11, 2005 i get a low coolant light that comes and goes but my radiator is full and the resavior is right where it should be at hot or cold temps thanks Quote
supreme_style21 Posted September 11, 2005 Report Posted September 11, 2005 The sensor has gone bad then. Fairly common. Its a square-lookin deal at the neck of the radiator. Quote
jwagner166 Posted September 11, 2005 Author Report Posted September 11, 2005 Thank you very much ! This light was very anoying knowing it was full .Thank you again Quote
White93z34 Posted September 12, 2005 Report Posted September 12, 2005 you should also bleed the cooling system, there may be a airbubble in it that will cause that. Quote
THe_DeTAiL3R Posted September 12, 2005 Report Posted September 12, 2005 The sensor has gone bad then. Fairly common. Its a square-lookin deal at the neck of the radiator. They can get gunked up with old green gooo also, so cleaning them sometimes works too. Quote
