JakeMetz63 Posted September 9, 2005 Report Posted September 9, 2005 http://www.tomstrongman.com/RoadTests/Bonneville/Index.htm I mean would the pattern be exactly the same. These would look damn sexy on the 94 GP. Quote
RareGMFan Posted September 9, 2005 Report Posted September 9, 2005 I'm sure the bolt patterns the same. The issue is going to be offset, and whether it will clear your front calipers, or not. Quote
Tigershark Posted September 9, 2005 Report Posted September 9, 2005 I guess you could always take a grinder to your calipers.. it would not take much to clear that rim. Quote
GnatGoSplat Posted September 9, 2005 Report Posted September 9, 2005 Those resemble the aftermarket CSA's I put on my Cutlass (see link to the 89 in my sig for pics). They didn't clear the calipers, I had to do 3 things to get them on: 1. Upgrade to 96 style front knuckles to space the caliper bracket out further. 2. Shave about 5mm off the caliper brackets. 3. Add a 5mm spacer. The spoke design on those looks very similar to mine, so I bet they won't fit without a lot of work. Quote
Psych0matt Posted September 9, 2005 Report Posted September 9, 2005 Ive thought about that the numerous times ive seen those GXP's around here. Those rims are hot :shock: Quote
