Weird lump in drivetrain - Update: Problem Solved!!!
you should still do a tuneup if it hasnt had one in a while (gm spec is every 30K, iirc)
Tuneup was performed less than a year ago, including spark plugs, wires, oil change, fuel injector cleaner and fuel filter. I will be replacing the plugs in the next couple of days, as I highly suspect I have a bad one. If funding allows, I will also replace the coil packs.
  • Replies 60
  • Created
  • Last Reply
Top Posters In This Topic
  • Grand Moff Joseph
    16
  • DaveFromColorado
    9
  • GP1138
    6
  • 19Cutlass94
    6
tracking?
BTW, the current plugs are platinums, which is why I am removing them (at the suggestion of many here)
Yeah, I'm switching to AC Delco plugs anyway, though I don't have an LQ1.
iirc, rapid fires are platinum. tracking: look for black marks on your plugs. it's indicative of bad plug wires or coil. probably wont have any though since your wires are new.
Sorry to kind of go a little off topic, but what do you guys think are the best wires for these engines? Im going to be needing a tune up fairly soon. Just wondering what you think is the best.
Stock Delco.
Stock Delco.
not that I use these emoticons but :werd: - you can't beat stock Delco parts.
--Dave.
  • 1 month later...
bump.
Problems have been solved! See updated first post (page 1)
