Sleek 93 SE Posted September 4, 2005 Report Posted September 4, 2005 Instead of having someone burn a chip for a custom turbo setup, would an apexi safc work? If not, besides Ben, who would burn a chip for a custom turbo setup on a 3.1/4t60e? Thanks -Nick Quote
Sleek 93 SE Posted September 5, 2005 Author Report Posted September 5, 2005 24 views no replies, lol Quote
Guest TurboSedan Posted September 6, 2005 Report Posted September 6, 2005 Instead of having someone burn a chip for a custom turbo setup, would an apexi safc work? If not, besides Ben, who would burn a chip for a custom turbo setup on a 3.1/4t60e? Thanks -Nick i don't think Ben will burn a chip for custom turbo setups but i could be wrong. i don't even think he does TGP chips. i doubt there are many turbo 3.1s around with apexi safc. best bet is to start with a TGP chip and a 4T60 non E. you can do alot of stuff with GMPCM and a Willem EPROM burner. otherwise i would say Jud (sleeperred90tgp) would be the person to talk to about other methods. Quote
Bossman429 Posted September 6, 2005 Report Posted September 6, 2005 Jeff M doesn't do much with tranny swaps. 5 speed or 4T60-E from what I have heard and seen. Quote
Guest TurboSedan Posted September 6, 2005 Report Posted September 6, 2005 i would check out the GMPCM.com forum and ask Mick. Mick is the site admin there and i'm sure he can help you out (he's a very very helpful person and i'm sure he'd be willing to work with you). i'm not sure if people have been doing TGP code with a 4T60-E or not....or even if that is possible. if not, i still think starting with a non-E 4T60 & TGP chip along with tuning with GMPCM would be the way to go. Quote
Sleek 93 SE Posted September 6, 2005 Author Report Posted September 6, 2005 Thanks for the info about GMPCM Ill check it out. I still would like to know if the Apexi SAFC would work Quote
TurboGTU Posted September 7, 2005 Report Posted September 7, 2005 THe Apexi won't do you any good. Why..its only adding more or less voltage to what ever the map sensor is reading..to confuse the PCM thats its at another map reading. I have this unit..well the Apexi Super AFC II...but on a VAM'ed car. APexi don't do jack for timming. YOur best bet is a FMU and a retard box. Or swaping over to a Non E or 5spd. and use the TGP code. I know of one person who did a Auto 3.4 TDC code intergration with the TGP code. But it still had issues and was verry involved to do (trade secrets,,unless $$$). Quote
Sleek 93 SE Posted September 7, 2005 Author Report Posted September 7, 2005 If there is a transmission swap involved I may just say forget it and find another car to do it to. Quote
GutlessSupreme Posted September 7, 2005 Report Posted September 7, 2005 If there is a transmission swap involved I may just say forget it and find another car to do it to. You'd most likely have to anyway. Your 4t60E most likely wouldn't hold up to boost very long. Quote
mfewtrail Posted September 8, 2005 Report Posted September 8, 2005 If there is a transmission swap involved I may just say forget it and find another car to do it to. You'd most likely have to anyway. Your 4t60E most likely wouldn't hold up to boost very long. ^Yep. There are parts for 4T60-E's to make them hold more than anyone here will likely see though.....but you gotta pay to play. Quote
J Posted September 8, 2005 Report Posted September 8, 2005 i've been told numerous times that a 4T60 won't hold up to boost very long without a performance rebuild either. So just get a 5 speed like i did and be done with it Quote
