93CutlassSupreme Posted August 29, 2005 Report Posted August 29, 2005 how long does it typically take for a clutch to break in? i put a trans and a new clutch in this car at the end of april, and this clutch has been grabby as hell since it was replaced. it takes a ton of gas to get this car moving, more so than any other stickshift car i've ever driven, and they were all 4 cylinder cars the old clutch wasn' this grabby Quote
J Posted August 29, 2005 Report Posted August 29, 2005 did u glaze it over already? and did you resurfacee the flywheel? Quote
1990lumina Posted August 30, 2005 Report Posted August 30, 2005 My friend replaced the one on his 96 2.2L Cavy and it took maybe 2-3 weeks of driving to "break it in" (not extremely grabby off the line) All they did was roughed up the fly wheel with some sand paper and it's been working fine ever since. Is there some sort of adjustment you could make possibily?? Quote
DaveFromColorado Posted August 30, 2005 Report Posted August 30, 2005 ... did you bleed the hydraulic system for the clutch? (I've seen that be a problem before) Usually clutch break in should take about 10 seconds for a stock clutch, and about 100 miles for a performance clutch. --Dave. Quote
