K8JWT Posted August 28, 2005 Report Posted August 28, 2005 I am having a wired problem with my 1994 Pontiac GP. 1. It is sometimes hard to start as when you turn the key all of the lights go out but if you key switching the key on & off after a few tries it starts. 2. When driving, the dash warning light that is on due to the EGR valve, dims whenever the turn signal is blinking. Also speedometer & tach needles move when blinkers are on. 3. With the engine running, if I turn on the headlights it alomost kills the motor. 4 A few times recently the car will shut-off while driving as if there was no electrical power going to the vehicle as I lose ALL lights,buzzers,everything but if I wait a few minutes it will restart and run fine. Had the altenator and battery tested a 2 different auto parts stores today and both said the battery & altenator are working fine. I AM LOST NOW! ! ! ! ! !
GP1138 Posted August 28, 2005 Report Posted August 28, 2005 You already posted this in the correct section, there's no need for it to be here too.
